Please suggest me a motherboard for i9 10850K
Solved by Mateyyy,
At around the same price as the Z490-H you should be able to get a Z490 Gaming Edge WIFI, Z490 Vision G, Z490 Tomahawk or Z490 Aorus Elite. Maybe even slightly cheaper.
But to answer your question, no I don't think the Strix Z490-A is worth $50 more over the H. That being said, if you liked the white theme of the board, the Prime Z490-A is pretty much the same as the Strix, save for BIOS Flashback I think.
