Connect rtx 3080 to 4+4 cpu
Zoltus
I have cs750m and can i connect rtx 3080 to it? Few 3rd party sellers said that it would support it and some say it doesnt
My power supply is semimodular so it already has buildin cpu and motherboard connectors.
Mine looks like this https://i.imgur.com/51iEoLG.png
but problem is other 8pin says 4+4 cpu, so can i use it?
Yes you can, both of those sockets on your psu are the same the only difference will be the cable you use whether it has cpu 4+4 or pci-e 6+2 on the end of it
The connector on the power supply which says "6+2 PCIe & 4+4 CPU" can be used to plug in either a 6+2 PCIe cable (for graphics cards!) or a 4+4 cable for CPU power.
For plugging in to the graphics card itself it will need to be a 6+2 PCIe cable. You cannot plug a 4+4 CPU power cable in to a graphics card.
I have 3x cables, 2x cable where it goes from 8pin to 6+2, and one where it goes from 8pin to two 6+2 pins
So you are saying i can use my 2 cables which 8pin to 6+2 with rtx 3080?, with my psu slots which say 4+4 cpu and 6+2  pcie-e
Yes.
Yes you can use those cables. It says "6+2 PCIe & 4+4 CPU" because you can use either one in both of those sockets, not because one is PCIe only and the other is CPU only. Everything incompatible in a computer is physically incompatible. Unless you go around pushing connectors into sockets as hard as you can you can't get electrical connections wrong.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
You can use either the single 8 pin to 2x PCI-e or use the two 8 pin to single pci-e cable, personally I would go for the later
what?:D i mean i have to connect 2x 8pin to 3080
i've seen people plug floppy disk power into fan header
it fits right in afaik
instant fried motherboard
-sigh- feeling like I'm being too negative lately
I head my friend connecting something wrong and fried 500 euros motherboard with harddrives
I'm interested in this aswell: So you're basically saying 4+4 CPU and 6+2 PCIe cables are running the same specs but the connectors are different? So you can basically use adapters to make them work?
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
1 minute ago, Stahlmann98 said:
I'm interested in this aswell: So you're basically saying 4+4 CPU and 6+2 PCIe cables are completely interchangeable and the connectors share the same specs?
What do you think, can i use my 2 cables which are 8pin to 6+2 and my psu which has 6+2 pcie-e and 4+4 cpu slot?
PCie and CPU connectors both use 12V and ground. CPU is 4x 12V and PCIe is 3x 12V (the +2 on PCIe are just sense wires). You cannot plug a 4+4 CPU connector directly in to a graphics card, or a PCIe connector in to a motherboard. CPU has the 12V across the top row and PCIe is across the bottom row.
AX1200i Questions - The Corsair User Forums
Because it's just 12V and ground wires it's possible to use the same connector on the power supply for both CPU and PCIe - Though not all power supplies do this.
It's possible to use an adapter a 4+4pin CPU connector to a PCIe connector, though I normally wouldn't recommend adding additional adapters as it just adds additional failure points and increases resistance across the cable. Typically speaking power supplies will have more PCIe cables than CPU power cables anyway. Most power supplies only have a single 4+4 connector, though some higher wattage models will come with two. Typically though PSUs with 2 CPU cables will have at least 2 PCIe cables as well so unless you're powering multiple GPUs you shouldn't really have any need to adapt a CPU connector to PCIe.
With modular power supplies you could always just get another modular cable compatible with your model of power supply. The CS750M that OP has uses Corsair's Type 3 cables which are also compatible with Corsair's Type 4 PCIe and CPU power cables.
I have 2x type 4, 8 pin which split ionto 2x 6+2 pin connector, Can i use those or do i need adapter? srry im a bit confused with all this and want to confirm because putting a lot of money on this!
Yeah those are fine. If you can use both cables with one connector from each cable just to spread it over the two cables since the RTX3080 can draw up to 370W in some situations.
Type 4 and Type 3 PCIe connectors are the same. The difference between Type 3 and Type 4 was on the motherboard 24pin, but since your power supply is semi-modular that doesn't apply.
Ye so i will just leave 1x 6+2 pin unconnected from both cables, Sick i literally cant thank ur help enought :)
In modern PCs then. No new PSU that isn't a $15 Shenzhen special has had a floppy connector since at least 2015. Excluding legacy replacement PSUs anyway.
¯\_(ツ)_/¯
Desktop:
Laptop:
Pretty sure many PSU still comes with a molex, chain with a floppy end or molex to floppy adapter
Think my seasonic I bought in 2016 had a molex chain with floppy at the end of it
My corsair rmx (2018) and cxm(2019) have molex to floppy I think
Really? My CX750M I bought mid-2016 had neither.
¯\_(ツ)_/¯
Desktop:
Laptop:
