CPU-Ryzen 2700x
Motherboard-ASUS Prime x570-p
Ram-Corsair Vengence RGB Pro 4x8gb 3600mgh
Hello, I am very new to pc’s and asking for help I just built my first one with some of the specs listed above and I’m having trouble running the 4x8GB sticks at 3600 MHz the board is rated to run that, if I run dual channel at 16 gigs I can overclock it to 3600 MHz just fine but is soon as I put the other two in it’ll boot up in the safe mode, Is my CPU not be beefy enough to run all that memory, Would it be better to run dual channel 16 gigs at 3600 MHz or quad channel 32 gigs at 2133 MHz
https://linustechtips.com/topic/1247217-memory-not-overclocking/
Zen+ CPUs dont overclock memory well, you need a newer architecture of Zen CPU to do 4 sticks 3600MHz
Desktop benching:
running 4 sticks at 3600 on zen +'s imc is quite a bit of pressure.
set the soc to 1.15 and dram to 1.35 and go for 2933, check stability and go for 3000 and then 3200.
Phone: Pixel 3a (Purple-ish).
Build Log:
what CPU would I need to run all the memory and what’s better 2x8 3600 or 4x8 2133
I mean performance wise, assuming your workload does not need more than 16 gigs, technically 2x8 will perform better, buy if you need 32 gigs, capacity will be more important.
as i said though..
Build Log:
16 minutes ago, brock09973 said:
would a Ryzen 7 3700 X work or do you need something even better than that
all Zen 2 CPUs would do that, though moving to 3700x or above make more sense when you have a 2700X
13 minutes ago, brock09973 said:
if the 3700 X won’t work what would and is it better to run 4x8gb 2133hz or 2x16 3600mgh
You can still try higher frequencies on 4x8gb, like 3200MHz
Desktop benching:
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
as i said though..
another question by chance do you know if I put my base clock on my CPU to 4000 will it still fluctuate and give me more during games and less during no workload
22 minutes ago, brock09973 said:
another question
I mean you can just overclock the cpu and let it idle at lower frequency to save power.
Not sure why you'd do something like this.
Edited by TofuHaroto
Build Log:
