RGB or not
5 members have voted
  1. 1. Do you care about your PC's visuals/RGB or not?
    • Definitely has to look fancy/care about RGB/colour or other attributes
      2
    • Not bothered by looks, won't pay more just for RGB or the visuals of an item
      3
Ugh, poll is too limiting. I want my PC to look nice but think RGB is disgusting.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1246565-rgb-or-not/#findComment-14019207
Well the poll is not about cable management. Voting the 2nd doesn't mean you have a cable salad in your case but if you're willing to pay more to have pretty parts, even if they don't have RGB you can just vote the first since it's about whether people would spend more for how an item looks without performance improvements.
https://linustechtips.com/topic/1246565-rgb-or-not/#findComment-14019217
1. there is more to a nice looking PC than cable management (or lighting if that's your thing)
2. the second option is literally "not bothered by looks" lol
SPECS:
https://linustechtips.com/topic/1246565-rgb-or-not/#findComment-14019219
I changed the choices so you should feel fine voting the first
https://linustechtips.com/topic/1246565-rgb-or-not/#findComment-14019237
rgb is a pain (coming form the rgb god....) there are other ways of doing it and make it look good or cheap then just buying this rgb and that rgb.
imo if you want to get in to rgb cheap just buy a strip and go from there, work out the software to see even if you like it.
that being said there are REALLY nice looking non rgb builds also. just the market is about rgb right now.
https://linustechtips.com/topic/1246565-rgb-or-not/#findComment-14019534
