Greetings LinusTechTip community, I own a Gigabyte RTX 2080 Gaming OC of which is the apparent coolest non-liquid RTX 2080 available. Upon purchase and use of this card, I noted down temperatures of 70-75c regardless of length of load. The fans were spinning at roughly 1,600 RPM. Nowadays however, my graphics card runs at 70-85c with the fans at 2,500 RPM.... It is not summer where I live, so that is not the cause nor is dust build up as I have checked. Could the thermal paste require replacing already? The graphics card is two years of age nearly.
https://linustechtips.com/topic/1246564-graphics-card-temperature-increased/
It's possible, they are meant to last as long as the warranty but usually they don't
my laptop needs repaste after two months, for example
Desktop benching:
Would definitely try replacing the thermal paste with something better.
Imo the gaming oc or any cards with the  windforce cooler cards aren't the best for cooling. For example the ftw3 cooler runs high 50s overclocked with a 2080ti, and the xc black stays under 70.
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
Sounds like something is drying it out way to fast o.o Is it getting proper contact?
It could use a repasting but honestly just sounds like you may have updated a few drivers and slightly changed the performance and depends on the game and usage.
Screws aren't as tight as I would like them to, but they are pretty dry, hard and thin with proper contact.
Desktop benching:
there was a thread complaining about gigabyte 20 series gpu's paste not long ago (think ytd?)
a few people had issues with their GPU, different models too
both of them solved their own by repasting, mine had to be RMA-ed, because repasting didnt fix it
-sigh- feeling like I'm being too negative lately
Might want to try a different paste then. PK-3 doesn't dry out in 3 years at least. (I have a laptop with it, so this isn't just marketing)
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
The one that dried is the factory paste, my stuff works fine
Desktop benching:
Ah, yeah laptop manufacturers rarely use anything that will prolong the life of the device. It was probably sitting in a warehouse for a year or two before you bought it.
