Mic for Discord and Recording
Solved by The Flying Sloth,
I disagree, if you already have the 57 just pick up an inline preamp for it, the 57 will be much better than any cheap condenser for recording guitar amps and with the preamp will be much easier to drive. Condenser mics will also definitely pick up the AC noise (especially pseudo-LDCs like the 2020.) The cheapest option I know of is the Klark Teknik CT1 and it's just as good as the Cloudlifter and Fethead.
If you're looking for other options or more info the recommendations list in my signature may be useful to you.
