the vsoc mos temps tend to get pretty high 76-81C , on my gigabyte b450m s2h and 3200g . this happens only in games because the iGPU start using the RAM MEMORY (which is 3600mhz CL16).  in any ram stress test like prime95 large fft the VSOC Mos temps not going higher than 50C, vrm mos as well stay at around 45-46C in load. is this a safe temp for the vsoc mos? i ask because sometimes i get stuttering or sudden fps drops in games like cs go and wonder if not the vsoc mos temps have something to do with it
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/
76-81C is safe.
Just now, bluehillday said:
i ask because sometimes i get stuttering in games like cs go and wonder if not the vsoc mos temps have something to do with it
81C is way below the throttling point, so I think your culprit's most likely elsewhere.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005590
Yes, mosfets can operate at around 125c without getting damaged, these are perfectly safe.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005591
is that valid even for the vsoc mos? i know that the VRM MOS can take 100C+ , but are the vsoc mos made of same stuff but have different role?
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005597
They're the same thing. so yes.
but are the vsoc mos made of same stuff?
still the same thing, heck i think they're even the same model on the s2h, and they're 4C010N and 4C06N afaik.
Build Log:
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005599
too bad that the board doesn't have a heatsink for the vsoc mos because the vrm mos have one, and they are pretty decent
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005620
but yea again, those temps are fine.
Build Log:
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005625
1. It's safe
2. It's hot not because of pulling RAM a lot, but the GPU itself. GPU on APUs are powered by the SOC VRM and on low core count CPUs, could easily draw 80% if not more power than the CPU cores do.
Desktop benching:
https://linustechtips.com/topic/1244918-high-vsoc-mos-temps/#findComment-14005649
