Daisy Chain Fans
FrostMyFlakes
So in the efforts to keep wiring low on my PC build can anyone recommend Daisy Chain Fans for people to find. Im looking for some in White myself. Keeping my eyes on the Uni Fan SL120s but Idk when those are coming out !. Hopefully this also helps people who want less wiring in their PCs
Can you use fan splitters
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
In my system for fans that will be permanently daisy chained, I just splice them together. My Define R4 came with a very simple controller. I have 3x 120x38s spliced onto a single channel running at 7v because they are loud af at 12v. I have two other 120x38s that are quiet at 12v because they are 24v fans and I just have them running off mobo headers,
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Arctic does daisy-chaining with fans. But that limits quite a lot your selection. If you can run splitter behind mobo, thats a lot better.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I just watched JayzTwoCents' video on the Unifan sl120s and they seem amazing. You definitely should look into those. I dont know when they will be available again, but some people already got them and newegg is estimating that they will be back on the 16th.
The video I was talking about:
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Arctic F120/P120 PWM PST, you can daisy chain up to 5 fans and run them off one header.
 If you want something more spicy,  Bionix version fans are available (higher upper RPM limit, , but they are more expensive and you can't buy them in value packs.
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
@zeusthemooseyeah those r the fans Im waiting for ! very excited the few wires the cleaner the case :D I planning to make something nice in an InWin 925 but I was as few wires as possible and those fans got my eyes on it XD Was thinking a white and black mix in that case.
