3 minutes ago, Halfdan said:
This will be my first mount, I don't have any expirience.
What is the pro / con of 2 single arms Vs one mount with two arms? Can't really decide with what I should go.
Dual arm pro:
- one thing to mount (single leg to mount to desk)
Two single arms pro:
- if you are using two different monitors, it's easier to make sure they are both at the same height (as the VESA mount on the back of a monitor may be at a different height than the other monitor)
https://linustechtips.com/topic/1243823-dualmonitor-mount/#findComment-13996931
