Hi i mainly posted this for suggestions on the components. I dont want overclocking nor liquid cooling. Of course the parts list is below.
I5 4670k
Asus z87 pro
780 ti (gigabyte vs evga they cost the same)
Vengeance 4gbx2 low profile
500 gb evo
Corsair cs 650w gold
8/8.1 64 bit
They will all live happily in an arc r2 midi. Im only going to play games on a 1080p monitor @144hz. Mostly battlefield 4.
https://linustechtips.com/topic/124252-first-computer-build/
don't want to overclock get xeon 1230v3 with b85/h87 mobo.
https://linustechtips.com/topic/124252-first-computer-build/#findComment-1652866
change the motherboard to Maximus VI Hero
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Seagate Barracauda 2TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
https://linustechtips.com/topic/124252-first-computer-build/#findComment-1652929
This.
Or, if you want to save more money go with a non K processor. The K series is a waste of money if you don't plan on over clocking.
The H87 board will have the most expandability for future upgrades compared to the B85.
With the money you save you should be able to afford a 750gb EVO.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/124252-first-computer-build/#findComment-1652974
As has been stated, either go with a non K cpu, or go with a Xeon. No reason to loose money for nothing :)
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/124252-first-computer-build/#findComment-1652984
