Before considering new parts to put in my system, I'd like to know my current power consumption. I know I can find the estimated consumption for a given CPU or graphics card, but is there a program available that shows current wattage in or wattage used? Thanks in advance.
HWMonitor mentions power usage on certain CPU's and GPU's, but that cannot be seen as very accurate.
The best way to measure power use is directly from the wall, using a device like a kill-a-watt.
Alternatively, you could kind of guess the current power use, by looking at review for your CPU/GPU and seeing how much they would use in 100% usage scenarios.
They give a good general idea, but don't show everything like the power spikes etc...
Takes better equipment that if one wats to be accurate...
Corsairs PSU link software used with the RMI, HXI and AXI is much better in that respect.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Where are you concerned about the power usage? At the wall, or by the components themselves? VRM's and PSU's aren't 100% efficient, and things like drives and fans can make a big different to idle consumption.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
I'll consider that on that end. I suppose I could use that stat and factor in the theoretical efficiency of my power supply to calculate my system's power usage.
Just now, Ankerson said:
power spikes etc
That's not really what I'm looking for, because under a consistent load/benchmark, I don't need a second to second analysis. Would just like to know on average how much power my PSU is converting in a scenario where my hardware is under a heavy load
Definitely by the components, or in other words, how much my power supply is generating when my components are being mostly fully utilized. Though it seems the solution would be to measure wall wattage and multiply that by the efficiency of the power supply.
But you can't get an average without looking at the spikes etc.
Explain the purpose of what you want exactly.... And how you are going to use it and what for exactly.
Technically, but if a wattage meter pings say every 2 seconds, that's more than sufficient for determining an average system load ±10 watts in my estimation. I just want to estimate (key word estimate) my current system load to compare to the listed hardware TDP to then make that comparison to the TDP of parts I'd like to buy. This way, I get a more realistic estimate of how TDP stacks up to real use-case power consumption.
OK...
I can tell you it's not even remotely close... 🤣
That why people tend to add in a buffer wattage wise...
But carry on. :)
Even that solution is only a ballpark figure. It'll get you within maybe 50% error or so, but low end gets really hairy. Definitely not within 10 watts. The efficiency is related to power draw, and quite significantly so. Realistically the power estimations are going to be a better calculation.
Because that would require communication with the PSU itself, the answer is "no"... unless you have a Corsair "i" enabled PSU.
Curious... if you're buying new parts, why do you want to know what your power consumption is NOW?
Good to know.
Yes, there are curves for certain power supplies, so this could be used if you could measure wattage accurately. But since you can't, seems like that's out of the question.
That's an easy answer, didn't know about those.
That just seemed like a simple way to determine whether or not I'd need to budget for a new power supply if the requirements are close before actually getting all the parts installed and having crashes. Seems simpler to just plan on always having ample headroom, though.
There are PSU calculators, Seasonic is one of the best ones.... You can even add in overclocking...
They build in a buffer....  And they really aren't as bad as some make them out to be...
1 hour ago, redsquirrel0249 said:
I know. They're a perfectly reasonable option, I was just curious about an alternative, now I know there isn't one.
It's almost impossible to narrow it all down without lab equipment really.
