Low End Graphics Card For My Brother
Monti
Hello everyone. I don't know if this is in the right section but on to my question. My brother likes to play minecraft and also likes to record it for his friends (I don't understand why). Right now he uses a laptop with a AMD a6 and 4 gb of RAM and he can't get good frames when doing his recording. I have a old desktop with a Intel Pentium d and 4gbs of RAM. But it doesn't have a graphics card. He will be playing on a 1280x1024 and he has about 75 USD to spend. So what could he possibly buy that could run the game well when recording or would it be better so stay with the laptop? Any retailer is good. Thanks for any help.
Also is a Pentium D capable of recording at the same time as playing?
CPU-- AMD FX-8320 (Stock), Motherboard-- ASUS M5A99FX PRO R 2.0, RAM-- Team 8gb 1600Mhz, GPU-- Sapphire 7870 GHz with OC Edition, Case-- NZXT Tempest 210, PSU-- Corsair CX600m, HDD, 1tb Seagate & 2tb WD External, Monitor-- Dell S2240M IPS Display, Keyboard/Mouse-- Some Logitech keyboard and some Dell mouse, Speakers-- Logitech Z533
Save for a 750 or 750ti
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
He could get a recording device.
Diamond 5 in League :)
R7 265
id dont think there is a card that fits that budget and able to play games
Specs
I would recommend a used GTX 550 Ti
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Since when was Minecraft GPU dependent?
The GTX 750 would be good for the fact that it records through the GPU itself with about a 10% performance hit (if not less). I'm completely unsure if ShadowPlay can record Minecraft or not.
if you have to insist you think for yourself, i'm not going to believe you.
R7 265
His brother has a Pentium D...
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Going to a Pentium D will be a downgrade from even a mobile A6. So this will likely not work given Minecraft is not really GPU dependant. It doesn't take much on either CPU or GPU, but the recording likely creates a lot of overhead on the CPU,
I am thinking this might be a problem too. Would likely need an external device.
Edit: Since the CPU might be a problem, you could get a card that supports video capture through the GPU, or get an external device, or if you still any to give it a try without resorting to the above, then just get any video card, as the specs are not all that demanding (the results may not be positive).
Ya since you all think there may be a bottle neck. Should I look around for a cheap motherboard and CPU combo? my motherboard doesn't support any other CPUs (Gigabyte Ga-8I945P-G) besides a Celeron and other Pentiums. I guess I could sell what I have now and see if there is something on ebay or at a goodwill. If you have any other ideas please tell.
I'd say double that budget and get a GTX 750Ti
Save.
The processor might choke to death.
Forgot to quote you guys in latest post
nice blank message
Specs
Get a new Mobo and a cheap i3. Daul core with hyper threading for $100!!!!
I would buy a Pentium D Extreme HT 3.73GHz
@Monti
My son plays minecraft great on his A8-6600K, which has an equivalent GPU to an HD6670. Though a 6670 would perform better. They range around the $75 price.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
The lowest I can even think about is a 6570. GTA: San Andreas @ 1024x768 at nearly maxed, steady framerates, and Portal at 1080p completely maxed, with 2XMSAA. Not bad, just don't get the HIS one I did. Loud POS. Double the budget and get a 750Ti.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
best bet is to just buy a used graphics card on Craigslist, ebay, or classifieds on LTT.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
@Monti
What about a r7 250 but I like the idea of a 66xx series of cards. I will look around for one
LOL probably true
We all got left behind.
