PSU cable compatability
19 minutes ago, Kisai said:No modular cables are compatible between brands. They may use the same connectors on each side, but they may be wired differently at the PSU end.
Well that's not completely true. Phanteks, ASUS, XFX, NZXT, and Seasonic are different "brands" but Seasonic manufactures the PSUs for all on them and all cables are compatible (at least, all of the newer Seasonic PSUs, like Prime, Focus, Focus Plus, X, G, and Core series). So not different brands, but different manufacturers. You can use CableMod's website for compatibility. If your PSU isn't listed, it's probably proprietary, like the Fractal Design Ion+.
31 minutes ago, Raizenmare said:Does anyone know if the pinout on a Phanteks Revolt X is the same as a Corsair RM750x? I'm building my mom a PC for Christmas and upgrading my system in the process. I have the RM750x white and would like to keep the cables since the white ones would clash with her case. But if not, then I'll just get her some extensions. Thank ya'll in advance.
No they are not. The Revolt X uses the same cables as Seasonic PSUs and not Corsairs. Just get extensions.
