Hi, i wanna hear if somone can give a advice about a case swap.
i bought a used 1st. gen Ryzen pc (good value) and i want to swap to at Meshify C case, with som better cooling. (mainly for the gtx 1080)
Im set on the Arctic P12 value pack with 5 fans, and i want to know what need to run them.
do i need a controller, or a hub, or something?
and how does fan control work in that instance?
Motherboard: Asus Strix B350 F
600W power supply
https://linustechtips.com/topic/1238587-i-need-som-advice/
do i need a controller, or a hub, or something? and how does fan control work in that instance?
Your board has 3 chassis fan headers, I would just get 2 fan splitters and plug in all 5 fans into the motherboard. You can control the fan speed/curve in the BIOS using that method.
https://linustechtips.com/topic/1238587-i-need-som-advice/#findComment-13956902
you can get a pwm splitter, as long as the fans don't exceed 1A, one header is enough, but you could just get 2 pwm splitters and plug all 5 to the board, any splitter will work and they usually go for cheap.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1238587-i-need-som-advice/#findComment-13956910
This will work:
https://www.amazon.com/JBtek-divisor-ventilador-convertidores-unidades/dp/B01EF9OI0O/ref=sr_1_3?dchild=1&keywords=fan+splitter&qid=1598372129&sr=8-3
This is just a general example, you can generally find them cheaper than this. Like others have said, you can get away with one header.
https://linustechtips.com/topic/1238587-i-need-som-advice/#findComment-13956947
