changing fans to Noctua NF-P12 redux's
Solved by fonzz1e,
5 hours ago, TheThymo said:Hi,
I'm currently using corsair ml120's (that came with my 360 aio) and two ml140's. After watching the video by GN about radiator placement, I decided I should change the position of my fans (case is pc-o11). My rad is going to the top, instead of the side. I could get some more ml120's but I think some NF-P12 redux's wouldn't look bad either. I checked and my fans don't go above 1100rpm currently, so then I'd go for the 1300rpm NF's.
The question;
Would there be any gain in upgrading to (a total of) 6 Noctuas?
u could also buy arctic p12 pwm, their 5 pack sale price is much cheaper
