Hey everyone, I attached my Prime95 small FFTs results while on 4.1 GHz 1,15 Volts and my CPU temps reached 101 degrees then I immediately restarted the PC so that my CPU doesn't get damaged. But I did not understand why I got such high temperatures on 1,15 Volts I mean yeah the Wraith Stealth is bad but I think this is abnormal. Is there an issue with my CPU or something? Could anyone help? Thanks.
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/
no, that's completely normal with the wraith cooler running p95 small ffts
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951126
What cpu exactly?
Only use hwinfo64 for ryzen temps monitoring and check temps.
If they are 101C check temps while doing your normal workload since prime 95 is not a load a cpu would encounter on a daily basis. If temps are normal under your not normal workload, I wouldn't worry about the prime 95 results.
If they are still high, re seat the cooler and re apply thermal paste, also Ambient temps? And remove the side panel and check temps.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951129
5 minutes ago, TofuHaroto said:
What cpu exactly?
I didn't check gaming temps yet just Prime95. My CPU is R5 3600 how can I check if the OC is stable without getting such high tenps?
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951138
Try cinebench r20 and check, (though not as much as a stress test as prime 95).
Also check temps under your normal load and check.
Build Log:
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951140
Alright, Thanks and also is it safe and possible to use R5 3600 at 1,15 V and 4.1 GHz?
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951151
Let it run at stock speeds and undervolt if you want. Overclocking with a manual multiplier on the stock cooler is a no-go.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951152
Why though? When I leave everything at auto with Core Performance Boost disabled it runs at 1.03V 3.6 GHz. 1.03 V and 1.15V aren't that different but at 1.15 I can achieve 4.1 GHz still a no-go?
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951161
Thermal paste?
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951218
Just making sure 😊 sometimes people forget,plus sometimes they put little piece of plastic on top of the stock paste to protect it
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951225
If your CPU "actually" running at 4.1GHz. The Cinebench R20 score should be around 3700.
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951230
Just now, redcan0 said:
Also, I am overclocking from Ryzen Master not Bios and Ryzen Master has this feature where when you apply the OC it also tests it. Will the test of Ryzen Master be enough to be sure its stable? or is Cinebench R20 or something must?
The Ryzen Master stress test. Forget it. Run OCCT or AIDA64 instead.
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951233
Is AIDA64 as heavy as Prime? I don't want my cpu to go 100 degrees again?
I don't use any program that put so much load on a CPU like Prime 95. So I haven't use it since Intel Haswel day. AIDA 64 and OCCT are much closer to what I actually use daily, like Blender. I get low 80C with stock cooler when stress test with OCCT small file size. CPU with default settings.
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951251
31 minutes ago, redcan0 said:
Is AIDA64 as heavy as Prime? I don't want my cpu to go 100 degrees again.
Download and run Prime95 26.6. That one doesn't have AVX and while it's still unrealistic, it's at least not stupidly unrealistic.
https://linustechtips.com/topic/1237807-why-is-my-cpu-so-hot/#findComment-13951323
