Case with rom slots or not?
Go to solution Solved by SavageNeo,
15 minutes ago, dkoudijs said:
Thanks for the info, I did take a look and these look great. Looks like the vote is to place the rom outside the case it looks like since the case designs don't leave space.
Didn't know the options, so this is really helpful.
oh yeah sorry.
try this: https://ca.pcpartpicker.com/product/rf3H99/cooler-master-masterbox-nr600-wodd-atx-mid-tower-case-mcb-nr600-kg5n-s00
or this: https://ca.pcpartpicker.com/product/ZHmxFT/fractal-design-focus-g-black-atx-mid-tower-case-fd-ca-focus-bk-w
or this: https://ca.pcpartpicker.com/product/vPp323/fractal-design-focus-g-mini-black-microatx-mini-tower-case-fd-ca-focus-mini-bk-w
or this: https://ca.pcpartpicker.com/product/D2HRsY/cooler-master-masterbox-nr400-wodd-microatx-mid-tower-case-mcb-nr400-kg5n-s00
Looking for a new case, since mine is pushing 10 years, and the fans are starting to die off.
This PC is used for gaming, and my server to share files on the network. So its on 24/7
I have the following in the case if you want to guess thermals.
asus B85M-E
i5-4590 @3.3
amd RX 570
3 HDD (1 x 256 ssd, 1 x 4 TB, 1 x 6TB)
and the reason for my question, 1 x Bluray burner. (Used to rip my Blu ray collection for in house streaming)
So what cases can provide decent thermals (No rads needed at this time) while still having a spot for one rom?
Or do I get a different style case and move to an external caddy for the rom. I only rip about 2 times a month, so the external speed I can deal with.
Thanks for any help or advice you guys can give.
P.S. - Live in canada, and upgrade my PC rarly as you can tell due to budget restraints as I divert most of the money to the family.
https://linustechtips.com/topic/1237005-case-with-rom-slots-or-not/
asus B85M-E
i5-4590 @3.3
amd RX 570
Budget?
Sub 200 CAD ? sub 150? dub 100?
What size is your PSU?
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
5 minutes ago, Quickstrike said:
Budget?
You know what I didn't give enought details, good point.
Budget - Sub $150
PSU - 650 watt (thermaltake, can't recall model right now, but under 3 years as I swapped out the old one)
Fans - Sure RBG would be nice, not needed
Same with a side window, but not critical to have
Quiet is a huge plus
Tower format
Budget - Sub $150
Tower format
Phantek p400A Digital= rgb
Phantkes p300A mesh =cheap
Phantek p300 A mesh with 2-4 silent wings 3 fan  =quiet
all have good airflow.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
You beat me by seconds...
https://www.newegg.ca/black-phanteks-eclipse-p400s-tempered-glass-atx-mid-tower/p/N82E16811854051
@dkoudijs if you go with a P300, just make sure your PSU will fit inside, if you have a longer psu you might have some problems fitting it in that case
oh yeah sorry.
All these are good options.
Coincidentally I just did this upgrade! (dead serious)
I was debating about getting a case with a 5.25" bay, but I just didn't like the look of any of them.
I went with a Lian LI Lancool II Mesh Performance.
LIAN LI LANCOOL II MESH PEROFRMANCE BLACK Tempered Glass ATX Case -Black Color -LANCOOL II MESH PEFORMANCE-X
Yeah, I paid over retail, but this case checked all my needs. (3X SSD and 3X HDD)
I have a external caddy for my old Blu-ray drive.
Vantec CB-ST00U3 NexStar USB 3.0 to SATA 6Gbps Optical/Storage Adapter, Black
The thread of my upgrade.
Hopefully this helps, or makes things more difficult.
My 2020 Upgrade: CPU: Ryzen 5 3600; MB: MSI X570 Tomohawk WiFi; Memory: G.Skill Ripjaws V 32GB 3600 MHz; Case: Lian Li Lancool II Mesh Performance; PSU: Corsair RM550X 80+ Gold; Storage: WD Blue 500GB SSD; Seagate 4TB Compute HDD; Monitor: GIGABYTE G34WQC 34" 144Hz Curved Gaming Monitor, 3440 x 1440 VA 1500R Display
Previous Components Still Using: GPU: MSI GTX 1070 (bought Used); Storage: WD 3TB Green HDD,WD 1TB Black HDD, SanDisk SSD PLUS 240GB
Previous Monitor I want to VESA mount: LG 29UB55-B 29" Ultrawide 1080p 60Hz IPS
18 minutes ago, dkoudijs said:
I was thinking about this type of caddy, just eats into my case budget. So will see if I can still get a decent case, and the caddy for the money or go with a case with the rom included.
Yeah, I went a bit over my $600USD upgrade budget. I basically bought a new PC without a Video Card.
