I bought the 34 esport duo as it cool 5c less than the nh-d15 according to this comparison.
Is that a good choice to cool a stock 3900x ?
(also note that my 3900x will be bottlenecked by my 2133 mhz ram, but it shouldn't be too much of an issue according to this video)
More info I won't use it for rendering but for active work like this.
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/
4 minutes ago, SnooPainting8310 said:
I actually expected 50% loss, so that's a good news !
Depends on the task but on average expect at least a 10-15% drop. Some rendering tasks and games have a far worse performance gap tho so depends on the things you do.
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944761
That's just false.
But it's enough for a 3900x.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944783
10 minutes ago, TofuHaroto said:
That's just false.
May be the video isn't accurate but this is what is shown in it, FACT.
And I am actually wandering if I should not just send back the 34 esport duo and use the stock cooler that comes with the cpu ? So I can save money for other component ?
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944808
i mean the 34 will perform better than the stock cooler and will probably be quieter, depends on how much you value that.
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944818
I mean is it safe for active multi threaded task ? But not as full multi threaded as rendering ? In this video you have the exact utilization of the cores that I am going to do, does that heat a lot the cpu ? Could a stock cooler keep that under 60c ?
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944833
Nope sadly, but anything around 85c wont throttle the cpu.
but as i said..
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944834
mean the lowest it heat the more long it'll live soooo
To a certain point I guess.
A cpu running at 85c is completely safe.
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944870
2 minutes ago, SnooPainting8310 said:
it's basically useless to go with the arctic ?
No it isn't.
As I said it will run it cooler. Depends on how much you value that.
You could test with the stock cooler and check.
Or just watch an actual video from a reputable source and check temps with a stock cooler and decide.
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13944886
1 hour ago, TofuHaroto said:
No it isn't.
Why is that video not reliable ?
And compared to intel's stock cooler how does the amd one compares ? Do they have the same performances ?
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13945074
Intel's stock is worse.
As I said check how the stock performs and then decide if you want to return the cooler or not.
Saying that a d15 performs worse than a 34 is just wrong.
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13945091
I never said that, the d15 does performs better !!! What I said is that it is 5c degree behind on one test, the gap is just not that big.
And the 34 esport actually keep a 95w cpu under 60c, which correspond to approximately the power used by an active stock 3900x. So it's very satisfying result !
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13945113
ah i misread that lol my bad.
yea as i said, if it's worth it or not depends on how you value that. but yea it's better than the stock cooler.
Build Log:
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13945117
3900X is not a 95W cpu on stock. It might drop to it if thermals are bad enough but with a decent cooler it will be 140-150W:s on full load.
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13947395
Yeah, stock 3900x goes around 142w according to ryzen master, 105w tdp, I did the math and according to it, the cpu will be arround 75c-80c if I engage it in a full-core sustained load (sustained 142w).
But I won't even do that, I'm just doing 3d modeling, not rendering.
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-13948044
  • 3 weeks later...
UPDATE : I finally got my 3900x, tested it with the arctic duo and it hardly go over 75c (wavering between 50-65c most of the time) for what I do... In fact, the highest temp I managed to achieve was 77c (thou If i persist I am sure I can go higher), sound promising !
https://linustechtips.com/topic/1237003-cooler-for-stock-3900x/#findComment-14003016
