Hey guys i hope someone gets this message because im litteraly crying because of my pc the specs are an INNO3d 1050 ti fx8350 16gb of ram a960+v3 mainboard
Let me explain : when i play my fps is at 240 for 10 seconds and the at 80 fps i looked up so much and the i found out that my cpu isnt working constant as it should cant somone pls download cpu Z because when i stress the cpu it is on 1.4k points for 3 seconds and the it goes down and down until 800 points and doesnt go up. I didnt overclock my gpu but one day i undervolted him so it worked for like 30 min the i had to go offline. the next day (btw i had msi afterburner windows startup) my problem with the cpu was back and now it doesnt matter how much i undervolt my gpu the cpu wont work anyway in games again so plsssss help it is getting more badly
i have the bequiet power 11 600w psu idk why there is a problem
https://linustechtips.com/topic/1236638-massive-fps-drops/
Take a deep breath. Wipe your tears, get your thoughts together and edit that word salad to make sense.
https://linustechtips.com/topic/1236638-massive-fps-drops/#findComment-13941618
Reset your bios. take the power cable off, take the tiny battery off the motherboard, wait 15 minutes, try again
https://linustechtips.com/topic/1236638-massive-fps-drops/#findComment-13941623
the few words that make up a part of what i can imagine would be a sentence makes it sounds like your cpu is throtteling
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1236638-massive-fps-drops/#findComment-13941626
the thing is that i yesterday found the perfect undervolt on my gpu but i cant remember what it was
https://linustechtips.com/topic/1236638-massive-fps-drops/#findComment-13941643
1 minute ago, Biomecanoid said:
power cable off
battery our
wait 15 min
battery in
power in
start computer
update date/time in bios
load windows and test
ok but i still cant get into bios my keyboard is off in this moment when i have to spam del.
https://linustechtips.com/topic/1236638-massive-fps-drops/#findComment-13941727
