Hey guys,
So I am building a desk pc and long story short I need 2 3.0 internal headers, I have tried looking for adapters for 3.0 headers that go from one to two but I have not found anything, but I have found 2.0 headers to 3.0 headers what are the cons? Will I loose speed and how much?
https://linustechtips.com/topic/1236034-usb-headers-on-mobo/
You have a better chance finding USB 3.0 controller cards, i.e.: https://www.amazon.com/SupaHub-Expansion-Expanding-Internal-Connector/dp/B07R8SLRWS/
Lower speed is the con.
USB 3.0 speed: 5Gb/s / 5000Mb/s*
USB 2.0 speed: 480Mb/s.*
*theoretical max, realistic speed is lower.
https://linustechtips.com/topic/1236034-usb-headers-on-mobo/#findComment-13936657
Unfourtantly it's a bit too pricey I found this on Ali express- https://www.aliexpress.com/item/4000621126124.html?spm=a2g0o.cart.0.0.17e83c00e1sWIK&mp=1
will the cons remain the same and will it work at all? (im asking if it will work because of it's cheap price, even though that's nice.)
https://linustechtips.com/topic/1236034-usb-headers-on-mobo/#findComment-13936726
In theory that should work, but I can't vouch for the quality or integrity of this cable.
https://linustechtips.com/topic/1236034-usb-headers-on-mobo/#findComment-13937864
