Hello there!
I am planning on  a new build, but in this build I want to mount a figurine inside the reservoir , I am wondering what material is safe to use. I am planning to design a model and 3d print this, so it is crucial I use material:
- To resists the heat which a reservoir can maximal get
- Will not degrade over time due too liquid.
Does anyone have any idea about what material to use, or where I can find more information about this?
Beneath this mask there is an idea, and ideas are bulletproof.
https://linustechtips.com/topic/1235727-advice-on-decoration-material-inside-loop/
15 minutes ago, Swiebertjeee said:
Hello there!
Pretty sure Jayztwocents did a video on the pros and cons of different types of fluid dye. I cant seem to find it but I know it exists.
I will keep looking for you.
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
19 minutes ago, Swiebertjeee said:
Hello there!
I completely misread your post, wow Im tired, sorry about that.
Windows Gaming PC
120GB SSD
120GB SSD
36 minutes ago, Swiebertjeee said:
Hello there!
I guess PETG should be a good fit, however I can't say the same for any color seeping out.
Will that damage any parts within the loop? I don't want that to damage rads or anything.
No worries :)
No worries :)
PETG is okay as it what hardtubing is made of, you don't want little shards coming off it, but that's more to do with the print than the material.
I would potentially look at a something SLA printed in a waterproof resin, or possibly SLS printed in waterproof polyamide. Both processes have far less risk of fragmentation than traditional 3D printing and also offer far higher resolution and accuracy. They used to be very expensive but there are a number of providers who do both for very reasonable costs. I've had several custom SLA parts made now (pump bracket, GPU brackets and an IO cover) for a total of about £45 including dying and tumble finishing.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
What companies do you use to provide these objects? Is it you send them a 3d design and they create it?
I've used 3DPeople here in the UK. https://www.3dpeople.uk/. Believe they ship Europe-wide.
These are my SLS prints in Nylon if you're interested- not waterproof but should give you an idea on quality.
IMG-20200604-163726.jpg&key=96313351f5ba
IMG-20200714-134151.jpg&key=dcabaa7d299b
IMG-20200714-134207.jpg&key=0addd3407019
Correct
