It seems that its either deal wiht it or buy a new one. Please help me find a better sound system. I am looking for quality/price.
And I really do want to factor in durability. I really liked this one. except for the tone control. But I bet a digital software equalizer does the same.
It's almost like some sectors of the industry are in such a way, that 2 years before defection is normal.
http://www.shopbot.ca/m/?m=Altec+Lansing+vs2621
This is the one I have, what should I do?
My left stereo speaker (only) makes an electric noise, its not very loud. But it definitly annoying to an extent.
The electric fuzz is:
-continous
-The sound is very unidirectional.
-Only there when powered.
-Amplifier has no effect on it.
-Tone has no effect on it.
-The effect continues and is unaffected by unplugging the analog cable from the PC.
-After carefully checking there is no interference in the analog cable coming from the master speaker.
Audio equiepemnt in profile if that helps.
I would like knowledge, info, tips and anything else that could help me.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/123385-continuous-electric-fuzz/
Put the plug in an other outlet. I had this problem when it was windy outside, i've read somethong about that oxygen can couse the fuzz. Maybe cover it up with a blanket or so idk
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1641673
Tested that added new detail.
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642052
What do you mean?
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642094
What do you mean?
Tested your suggestion and added new detail to original post via editing.
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642188
Oh sorry i didn't see that, but i can't help you! :( The suggestion that i gave helped
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642197
I assume your talking about the volume, when you say the amp has no effect on it.
which leads me to believe there's a problem with the power stage of the amp.
what kind of speaker/amp system is it?
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642296
I have no idea. its a ALTEC lansing VS2621
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642375
oh, I thought it was a separate bookshelf set and amp.
don't know what to say other than deal with it, or buy a new setup.
https://linustechtips.com/topic/123385-continuous-electric-fuzz/#findComment-1642438
