Budget (including currency): $1000 willing to go over by $100 or more for performance and longevity
Country: United States
Games, programs or workloads that it will be used for: Minecraft, GTA 5, Spider-Man and other triple A titles
Other details
existing parts list below(anything I should upgrade or return for a better gaming experience like a  GPU or cpu?) I’m trying to reach a steady 144 frames
https://linustechtips.com/topic/1233593-current-build/
4 minutes ago, JustAnotherDolla said:
steady 144 frames
Might be a bit difficult with a 5600xt honestly.
That m.2 is quite expensive. Knock it down to a 500gb in the $70-80 range.
Use the extra money to upgrade to a 5700xt or 2070S if you can stretch your budget.
ask me about my homelab
https://linustechtips.com/topic/1233593-current-build/#findComment-13915617
or you could go with..
if you want to be closer to 1000 bucks, honestly the txm and the SP11 are great so you could go with either one.
the first build does come with a compute and the second does not.
as for the case, i would get a p400a/300a but they were out of stock sadly. but the focus g is still great.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1233593-current-build/#findComment-13915641
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1233593-current-build/#findComment-13915661
https://linustechtips.com/topic/1233593-current-build/#findComment-13916560
