Budget (including currency): 1400 USD
Country: Philippines
Games, programs or workloads that it will be used for: mostly for games
PCPartPicker Part List
CPU: *AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor  ($207.00 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($179.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($94.99 @ Amazon)
Storage: ADATA XPG SX8200 Pro 512 GB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB GAMING OC 3X Video Card  ($419.99 @ Newegg)
Case: Phanteks Eclipse P600S ATX Mid Tower Case  ($219.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Best Buy)
Total: $1386.92
Generated by PCPartPicker 2020-08-11 03:03 EDT-0400
Is there any parts to be replaced before I start ordering?
https://linustechtips.com/topic/1233027-planning-my-first-build/
Hello,
For mostly gaming :
The 3600x is not worth it over the 3600 unless the price difference is >10$. Better ram and GPU.
Edit : New parts are coming soon (RTX 3000 in september for example) so I would wait until then.
9 minutes ago, Meganter said:
Hello,
For mostly gaming :
will b450 able to support the 4000 series cpu? and I cant stick with having the 2080 because of the price in our country which is around 920 usd
The B450 MAX will support the 4000 series CPUs.
Can you find the Radeon RX 5700XT? Probably a better pick than the 2060 Super.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
It will but will need a bios update (like B550 afaik). In any case I would suggest to wait that the stuff is out like new RTX, Big navi and Zen 4000.
yep rx 5700xt is around $40 more than rtx 2060 super but i was hesitant on picking it because of the driver issues i have read in some posts
gotcha. ill start ordering the parts aside from GPU and CPU
15 minutes ago, narrdarr said:
p1 nvme sdd $10 cheaper
why a p1? the sx8200 pro is worth the 10$ premium
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
The SX8200Pro has DRAM cache IIRC so yes it's worth it. SSDs aren't just capacity sizes.
Full Specs
Helios EVO (Main):
Delta - Laptop
yes i am aware its more than just capacity, both SSDs does have DRAM
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Or you could go with this.
Since we don't actually know how prices are where you live. It's a bit under the budget but it could be just around 1400 bucks where you live.
2 things I want to say, the case: I would go with a p400a but that was out of stock sadly but you could go for that.
And as for the 5700xt model, I accidentally chose a different model for the first build but you could go with either one.
Phone: Pixel 3a (Purple-ish).
Build Log:
