Python getting texts from particular parts of a file
Wictorian
So I am making an app with python and I want to open program/files.
First I get their location via user input and write it into a text file
So it would be something like this
steam : C:\Users\user\program files\steam\steam.exe
origin : C:\Users\user\program files\origin\origin.exe
(not exact location, just made it up for demostration)
So then according to user input I wanna get a file's location
say ı have steam and I wanna get C:\Users\user\program files\steam\steam.exe
how do I get it?
Just now, James Evens said:
XML is overkill but there are more then enough tutorials for it..
yeah, it is overkill. Cant I just do it with python? because I think it is doable.
I followed this tutorial to write data to a .txt file :https://www.guru99.com/reading-and-writing-files-in-python.html
I just dont know how to call data out of the file. Like each character would have an index number in a list, but in a txt file?
Just now, Wictorian said:
do I need to install something
other than pip install json?
Nope, just install the json package and you're good to go.
And how do I store the data?
In a .py file with json?
edit: oh it is actually built in
screw this, how can I reach a variable from another .py file?
You'll need to store it in a separate .json file.  You should have your program.py file and a data.json file (you can name them what you want), you can store it where you want but I'd recommend just storing it alongside the program.py file.
Really basic saving/storage:
import json
# load data
with open('data.json', 'r') as file:
  data = json.load(file)
# create new Key-Value pair
data['discord'] = 'PATH_TO_DISCORD'
# save data
with open('data.json', 'w') as file:
  json.dump(data, file)
main.py:
from otherfile import hello
print(hello)
otherfile.py:
hello = "world"
5 minutes ago, Souffle said:
main.py:
print(hello)
otherfile.py:
hello = "world"
otherfile or otherfile.py?
creating and writing to that is the same wih .txt ,right?
also I will convert this to.exe, then it would still work, right?
creating and writing that is the same wih .txt ,right?
also I will convert this to.exe, then it woudl still work, right?
You don't need to specify that it is a .py file, Python already knows this so you can just use otherfile without the .py.
Yes, it works the same way.
I'm not entirely sure if this will work the same way if you convert it to an executable.  I see no reason why it wouldn't, but I also don't know why you want to turn it into an executable.
because I want to put in taskbar and you cant put .py files
On 8/8/2020 at 4:59 AM, James Evens said:
It is possible but just pointing at tutorials is the fast answer as you gave zero input. Like not even "reading and writing files in pyhton" google search  result code. Otherwise the hint might haven been CSV which are much simpler then json and XML.
One option is just keep reading the stream until you hit a line end and define this section as string. Alternatively write a PDA to handle the stream. Other option look up if there is a function which returns the file content as array or gives them as lines.
I will just store the data in another .py file
On 8/8/2020 at 4:28 AM, Souffle said:
main.py:
print(hello)
otherfile.py:
hello = "world"
Sorry for late reply but must this import be at the top or can I write it wherever I want?
