raspberry pi not booting
Go to solution Solved by Daniboi,
so i managed to boot it and i think it was the mini hdmi cable that was being messy along with me and my dumbass not installing retropie right
hi,
just brought a raspberry pi and i have installed noobs onto an sd after i have formatted card. i have now inputted the card into the pi and the after market fan i have got powers up but no display comes up. i have no idea what i should do next. the red light is on but not green.
https://linustechtips.com/topic/1231299-raspberry-pi-not-booting/
Suitable power supply? SD card prepared using offical method?
F@H
GPD Win 2
NOOBS is just a manual file copy to a formatted card. But you need to make sure to format the card as FAT32, and OP likely hasn't done that.
F@H
GPD Win 2
because he didnt use balenaEtcher that would have took care of it
if it was useful give it a like :) btw if your into linux pay a visit here
You cannot use balenaEtcher with NOOBS. NOOBS is designed for manual copy, it's just a zip with files, not a disk image.
F@H
GPD Win 2
i never used noobs its dumb
10 minutes ago, Daniboi said:
so i just did that and the green light breifly came on but then no display happened
The first boot sometimes takes a minute or so to initialize the file system and show the display. Try booting again and come back in 5 mins
