I wanna build a pc but there is a problem . I have to choice
1) going with the ryzen 5 3600 with a 1650 super
2) going with the ryzen 5 2600 with a 1660 super
3) waiting until amd put their ryzen 4000 in the market and going with amd rx 580 or 570
*NOTE : I AM GUST BUILDING THIS RIG FOR GAMING ONLY.
https://linustechtips.com/topic/1231121-need-help/
what do you already have?
budget?
what about a 3300x?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1231121-need-help/#findComment-13895360
Can increasing your budget for a 1650 when you wait for 4000?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1231121-need-help/#findComment-13895372
4 minutes ago, the cool guy X_X said:
my problem is with bottleneck
Well a 2600/3600/3300x won't bottleneck  a 1660 super.
Consider the 3300x and a 1660 super.
Which at least in gaming, will perform better.
Build Log:
https://linustechtips.com/topic/1231121-need-help/#findComment-13895401
