Test that it works before you put it in the case
Put in the RAM before you put on an air cooler
Check your cases standoffs and if you need to put any more in, also make sure you find the right screws that go into the standoffs
Start with putting in the IO shield
Run the usually tricky and tight PSU cables like the EPS connector before you put in the motherboard
Builds:
https://linustechtips.com/topic/1231106-tips-and-tricks/#findComment-13895249
Get a magnetic screwdriver. Nothing like dropping screws into a PSU. I've done it once. Thankfully it didn't get too deep.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1231106-tips-and-tricks/#findComment-13895275
