rx5700xt issue
Solved by -rascal-,
13 minutes ago, MrBigD1409 said:Ok thanks man, for the thermal paste do i have to buy specific thermal paste or the ones that you use for the CPU are fine for the GPU aswell (i have the arctic MX-4), for the radeon settings everything default (https://prnt.sc/tu4riu , https://prnt.sc/tu4t1j ) and what can i do for the frequency that is getting stuck is it gonna fix when i double check better the thermal pads or do i have to twerk some settings to fix it.
Regular CPU thermal paste is good and fine. You need to / should change thermal paste.
Thermal pad you can re-use, so check make sure they are put back correctly.
Settings on Automatic, so it should be okay for now...need to resolve the temperature problem first.
