I found a laptop Im considering buying.
It has an I7-7700HQ, 16gb DDR4, 256GB SSD + 1TB HDD, and a GTX 1060 6gb.
It's gonna cost £450.
Should I buy this or save up for parts so I can build a custom built.
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
https://linustechtips.com/topic/1230387-i-need-some-advice/
Seems expensive for what you're getting. That's pretty old.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1230387-i-need-some-advice/#findComment-13889463
1 minute ago, 5x5 said:
What model? If it's used them no. You have no idea how much it has been abused, overheated, damaged and etc
It's user refurbished Grade C, its the Acer Aspire Nitro VN7-593G
System
CPU: Ryzen 5 3600
https://linustechtips.com/topic/1230387-i-need-some-advice/#findComment-13889473
Oh lol skip that immediately. Refurbished VN Nitro with no warranty. Recipe for disaster. The VN is known for its massive heat issues
https://linustechtips.com/topic/1230387-i-need-some-advice/#findComment-13889479
