So i had a posting problem earlier and got it solved, but now that my whole system is inside the case, i am getting no post, i did nothing differently and i have no clue what happened
Specs:
AMD Ryzen 7 3700x + Coolermaster cpu cooler
16gb G-skill tridentz 3200mhz
Sapphire RX 5700xt
B550 Tomahawk Moba
TX650M Corsair PSU
Kingston 250gb Nvme SSD
+ Connected inside the case
2tb x 2 barracuda hardrives
250 gb samsung ssd
My keyboard and mouse also turn on when the system does, but turns off again after a short while, then back on
https://linustechtips.com/topic/1230063-post-outside-the-case-no-post-inside/
Specs:
Sapphire RX 5700xt
B550 Tomahawk Moba
TX650M Corsair PSU
Just to clarify:
You click POWER button on case, fans try to rotate then everything shuts off?
PC mobo is grounded to a standoff or has metal touching the bare case material
If its not doing that, it sounds like its boot looping.  How many times do you let it turn off and on again?  When turning on a PC for the first time, it may be configuring ram timings, which will cause up to 3 boot loops before calling it a failed boot.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
3 minutes ago, Tristerin said:
Just to clarify:
Sorry for not clarifying. Everything turns on and runs, it keeps running, however i get no post to my display, ive tried Mobo and GPU output, so im certain thats not the issue.
The Mobo is grounded to a standoff
and i let the System run for about 5-7 minutes before turning it off again after getting zero post
Check that all the standoffs are in correct places. If there is a standoff in the wrong place, it could be cause a connection on the mobo that should not be there.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Specs:
Sapphire RX 5700xt
B550 Tomahawk Moba
TX650M Corsair PSU
250 gb samsung ssd
okay so i tried disconnecting the storage except for the NVME SSD, and my keyboard no longer turns off, but now i have a Bright red LED that is constantly on saying Boot
So you are just getting no Display - no POST (doesn't even post to BIOS) is not the same thing by any stretch of the means.
Are you plugged into the Motherboards display ports (VGA/HDMI/DP/DVI?) and not the graphics card itself which should be doing all of the displaying when plugged in?
Okay, so it turns out my monitor was just being an ass, and didnt actually want to shot "Hey you can press F2 or Delete now to access the bios" i turned it on once more and just spammed delete, and i got inn, but thank you all so much for the help
Woooo when building a PC getting no display or no post is never fun.
