Need advice finding a good Large Case
smogsy
Hey guys
need help finding a good large case that can support an asus Zenith Extrene
(Extended ATX Form Factor 12 inch x 10.9 inch ( 30.5 cm x 27.7 cm )
Currently have an Lian Li 011 Dynamic - however due to moving away from AIO back to noctua the side panel no longer fits (its like 3MM off)
have thought amount trimming it down but means removing ends of the heatpipes..
requirements
* good cooling (needs to support 2950x,1080tI)
* quiet
* minmal looking
first thought was fractel design R7 XL, but had quite few fractel design so lookking for other ideas
budget £<500
Phanteks Enthoo Pro II (this is the 719, but I went with the 719 because of how long it would be before that case came out vs when I built)
Pretty good selection here
https://uk.pcpartpicker.com/products/case/#X=0,50637&f=3&sort=-price&page=1
How quiet its gonna be will largely come down to the fans, I would recommend have 4 or 6 fans, (even push vs pull) running at a low rpm only ramping up when things start to get hot under load.
Other than that any case you like the look of and has easy to clean fanfilters gets my vote, good luck!
corsair obsidian I think 900D,or go with mine TT View 91 TG RGB.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
