so i am going to purchase ram, i have two options,
1) thermaltake toughram with tested latency of 19-23-23-42
2) G.Skill Ripjaws with tested latency of 18-22-22
which is better at latency? also why does the g skill has 3 sets of numbers instead of 4 like the thermaltake? whats does the extra "42" in the thermaltake latency suggest? which of these two options is better in terms of latency?
https://linustechtips.com/topic/1226206-ram-latency-help/
Thermal take is showing trac value.
What are they both priced at and what's the frequency of each kit?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854933
both priced almost same.. thermaltake a lil more due to rgb,, and frequenxy both are 4000mhz
https://mdcomputers.in/g-skill-ripjaws-v-16gb-ddr4-4000mhz-f4-4000c18d-16gvk.html
https://mdcomputers.in/thermaltake-memory-toughram-rgb-16gb-ddr4-4000mhz-r009d408gx2-4000c19a.html
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854939
well they're both most likely rev e, they'll perform  similar in the real world. though considering the ripjaws is cheaper and has better timings, i would go for that.
Build Log:
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854945
thanks.. was thinking the same... was confused because the thermaltake had that extra number... m gonna go for gskill.. better latency is more important than rgb
1 minute ago, boggy77 said:
lower latency is better. go for gskill
thanks
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854949
I already answered you low, the lower number. But okay, make another thread about it.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854951
12 minutes ago, Mahbub said:
what cpu are you running?  if it's ryzen using ddr4 4000 will screw you
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854960
OP is running an 8600k.
Build Log:
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854964
hey one last question.... i saw that the latency numbers are even lower on the 3200 mhz, so like which shud i go for 3200 with low latency or 4000 with higher latency?
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854965
Explains concept:
https://www.crucial.com/articles/about-memory/difference-between-speed-and-latency
I'd say the 3200 lower latency because there's no guarantee your IMC will like 4000mhz RAM anyway, and the 3200mhz is cheaper and will work.
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854972
If it's 3200 CL14 go for it, otherwise don't.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13854981
3 minutes ago, Mahbub said:
Whats cl14, i am a total noob at ram..
That's CAS latency. What you mentioned in your original post (18-22-22-etc.) are timings, specifically the primary timings of the memory. Lower/tighter timings = better, higher frequency (3200, 3600, 4000, etc.) = better.
1 minute ago, Mahbub said:
It says 16 20 20 38 on the 3200
That's junk, either of the 4000MHz kits you mentioned is better.
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13855008
Okk but the 4000 has even more latency.. so those also junk?
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13855015
No, it's got looser timings, not a higher latency. Selecting frequency and timings is a balancing act to get the best latency.
Speaking of latency, you can calculate the access latency of memory using either calculators online (like this one: https://notkyon.moe/ram-latency.htm) or by calculating it yourself with a simple formula.
For instance, just so you understand why those two 4000MHz kits are better than this 3200 kit:
3200MHz CL14 = 8.75ns latency
4000MHz CL18 = 9ns latency
4000MHz CL19 = 9.5ns latency
3200MHz CL16 = 10ns latency
The reason I said that 3200 kit was junk is that the other primary timings (20-20-38) were super loose for a 3200MHz kit, meaning it's most likely using bottom of the barrel DRAM.
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13855038
well then decision taken.. m going for the 4000 mhz
https://linustechtips.com/topic/1226206-ram-latency-help/#findComment-13855046
