cpu overheating
Solved by Mateyyy,
30 minutes ago, max8236 said:the airflow is not the issue i already tried it
Then the last possible culprit is the CPU cooler, I guess?
To answer your initial question, an NH-D15 should be a great pairing for the 10700K, with the Dark Rock Pro 4 and then the NH-U12A also being some solid alternatives.
kerriya ·
Posted in Cases and Mods6 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
