How loud will my PC be?
DarkAavenger777
How loud would my pc be with four of these fans? I also have an AIO kraken z63 and a 5700xt sapphire nitro plus edition with a Corsair rm 750. Plus I have a barracuda compute 2tb 7200rpm.
theres no way to know. It will depend on how hard the fans are working which depends on a ton of different factors such as room temp, case, temps, fan curves, and more.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
You're missing a link i guess. I don't know which fans you are referring to with "these fans."
But the AIO and the GPU are on the quieter side compared to reference cooler designs. The Corsair RM series is unnoticeable and one HDD should not be a problem. However, it is hugely dependent on your settings. Are you overclocking? If yes, how much? Do you use silent profiles and accept higher temps or do you wanna rock 60°C max?
Let's put it like this. Your setup, depending on your four fans, could be really quiet.
  • 2 weeks later...
okay thanks. i wont be overclocking. ill just game on it?
It depends on what case you are using. If it has horrible airflow, you cant make a quiet pc on load.
h510 elite
with 5700xt
r5 3600
corsair rm750x
and a barracuda 2tb hdd
1 minute ago, DarkAavenger777 said:
h510 elite
with 5700xt
r5 3600
corsair rm750x
Should be ok with an aio. Gpu might run a bit hot.
I would pick 3700x with a 20-30d tower over 3600 and that expensive aio. But I guess looks is more important now :D
