1 minute ago, Parsh said:
Basically I have Corsair vengeance ram and it only runs at 2133 MHz , I tried changing but in the end it says 2133 MHz so how do I fix that
Turn on XMP in your motherboard's BIOS.
The term used to describe this technology may also be: XAMP (some AMD boards) or DOCP (AMD boards made by ASUS)
https://linustechtips.com/topic/1224298-ram-speed/#findComment-13839809
Just now, Parsh said:
But even after I do do it it just says my memory is still running at 2133 MHz
Turn on XMP (or your motherboard's equivalent) > save and reset > don't touch the system for a minute (it may reset a couple times).
Does this happen or does something else happen? Where are you checking the memory speed? What specific memory set do you have?
https://linustechtips.com/topic/1224298-ram-speed/#findComment-13839816
If it's a 2133mhz RAM and that is its rated speed, then it'll only run at that speed, regardless of XMP profiles. If it's a higher rated module (say 3000mhz), then enabling XMP profile should automatically put it at its rated speed. If it doesn't, you can set it manually. Make sure that it's rated for higher speeds though, because it will NOT run if it isn't.
https://linustechtips.com/topic/1224298-ram-speed/#findComment-13839826
Done it boots up normally I checked on bios but @gloop told me to look at cpu z so that’s where I am it’s Corsair vengeance rgb pro 32gb ram 3200 mhz
https://linustechtips.com/topic/1224298-ram-speed/#findComment-13839849
