So, a friend of mine had the idea of building a switch sized console, with a raspberry pi, to use with gforce now; being quite interested in the matter I decided to somewhat help him.
So, these would be the components
raspberry pi compute module 3+ (or 4 when and if it comes out)
custom 3d printed case (we don't have a 3D printer but there are some places in town where you can get one made for cheap
custom board (you slot the compute module in that has a DDR2 SODIMM form factor. These have the plus side of being slimmer and not having the taller components, like ethernet and USB)
     for which the requirements would be:
          -Micro SD slot
          -MIPI DSI port (for the screen)
          -40 pin GPIO (I would use that for the varous buttons)
          -USB-C port, for charging
          -wifi
          -4G (or 5G when it comes out)
          -HDMI (if the 1080p screen is used)
a 1080p screen (or 720 if the DSI port is used)
analog stick and buttons
A battery
then
for the OS he wants to make a custom liunux distro, which, per se, is technically feasable, but the raspberry pi (3) has a really wonky boot sequence that could make the matter a harder.
Also building a distro isn't exactly easy.
In my opinion using base raspbian (or Ubuntu) and aventually modifying it is a better idea, far easier and with less overall hassle required.
So, what would be your suggestions, for OS and, well, everything else?
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
for OS I'd recommend either android or retropie
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
Maybe take some design inspiration and wiring from this guy:
It runs windows but the rest of it seems like something you want
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
Android sounds like a good choce, but for retropie, idk, he needs geforce now to work after all
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
