Where to connect fans in NZXT Kraken X63
Solved by Eighjan,
12 minutes ago, AncientPistol said:I'm building a PC with Ryzen 7 3700X processor on MSI B550 Gaming Edge WiFi motherboard. For CPU cooling I have bought a Kraken X63 AIO. The manual says to connect the fans to the motherboard or a fan hub, the problem is that the two included fans are PWM, and the motherboard only has two PWM headers - CPU_FAN1 and PUMP_FAN1, one of which I need for the AIO pump. There are 6 other fan headers - SYS_FAN1-6 that are all DC.
Where do I install the fan connectors? Do I need to buy a fan hub?
Correct - these two:
EDIT:
Try this:
