3 minutes ago, JINXtala said:
My power cut out while installing drivers and my desktop can't boot even to the recovery menu I have look for solutions on good and youtube and can't find any that work/have the same issue
try starting windows in safe mode
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1221628-help/#findComment-13818039
@JINXtala
Welcome to the forum. When it's in the state with the mouse cursor, hit Windows Key + R. If the "run" box comes up, type in "explorer.exe" If the desktop comes up, I can help you to repair the OS.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1221628-help/#findComment-13818175
4 minutes ago, svmlegacy said:
@JINXtala
Nothing comes up when I hit windows key + r
https://linustechtips.com/topic/1221628-help/#findComment-13818201
In that case, you must use a windows installation media to either repair the OS, or reinstall the OS.
An alternative is to attempt to start in safe mode, per @mahyar
https://support.microsoft.com/en-ca/help/17419/windows-7-advanced-startup-options-safe-mode
Specifically these steps:
  • Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
Edited by svmlegacy
Added more options
https://linustechtips.com/topic/1221628-help/#findComment-13818228
Ok, do this:
Shut down the PC.
Pull the power cable so that there is NO power going to the PC.
Press the start button for 15 secs.
leave the PC like this for about 5 minutes.
Plug in the power cable
restart the PC, and do not touch any keys, let it do it's thing.
let us know what happens.
https://linustechtips.com/topic/1221628-help/#findComment-13818301
23 minutes ago, The_Geek said:
Ok, do this:
Shut down the PC.
It has just been doing this since I did that
https://linustechtips.com/topic/1221628-help/#findComment-13818359
