So I'm building a pc that's basically like my existing pc for my friend and it won't post. The led light on the motherboard won't go farther than the yellow ram light. I'm not getting anything on my monitor. I've tried different ram and a different motherboard just to have the same issue. I've tried only using 1 stick of ram in eack slot and every configuration you can think of with the ram slots. I don't understand why I'm havothe same issue with 2 different motherboards and 2 different ram packs.
Specs
Ryzen 5 1600af
Rog b450 f strix
Corsair vengeance 2x8 3000
Xfx Rx 590
https://linustechtips.com/topic/1220889-new-build-wont-post/
Try re-seating the cpu ?
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
https://linustechtips.com/topic/1220889-new-build-wont-post/#findComment-13811559
did you clear cmos between the ram moving? remove the cmos battery for 30 minutes or so to clear it.
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
https://linustechtips.com/topic/1220889-new-build-wont-post/#findComment-13811588
