Got Adware/malware! Help please! :c Urgent
Go to solution Solved by JigglyPufflez,
Install and run AdwCleaner. It removes adware.
Spybot Search and Destroy is also a good choice in detecting adware/malware:http://www.safer-networking.org/
It usually comes in when you are trying to install another program and you agree to EULAs for multiple other programs they sneak in there (I think anyway, I never really get any malware/adware). First thing you should do is check through your program list and see if there's anything that looks suspicious. You might want to go through your program start up list and browser add ons as well, ccleaner works well for this. You can give combofix a shot as well after everything else is done, just be careful though, you need your anti-virus disabled and you can't run any other programs at the same time.
Start in safe mode, download and run rkill. Then scan your computer.
I think I may have fixed it, I ran a couple scans, deleted the "infected files" then to finally get it out of my chrome I had to delete the extension for "Allpricecheap" I have no fucking idea how it got to my extensions ._. I don't at all recall installing it to my extensions unless it does it automatically? Thank you for your help guys! I really and truly appreciate it <33333
So just found out I have some adware installed on my PC as I am typing this I am running a full system scan by Malware Bytes. Was just wondering any other scanners I could use to really get rid of this adware/malware? After the malware scan is done I am going to run an avast scan. Just want to know some other scanners I can use. Also if there are other methods I can use to get rid of these adware bullcrap. Thanks in advanced! I only just saw them now. <333
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/122053-got-adwaremalware-help-please-c-urgent/
Link please? Thank you though! :D <333
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
rkill found nothing going to run a system scan with Avast. Thank buddy! :D
No suspicious programs are on, yes I believe it snuck through and I didn't get to "decline offer" or what not
Spyware Search and Destroy is also a good choice in detecting adware/malware:http://www.safer-networking.org/
downloading it now. Thank you very much! :D
Double and triple check to be sure. An infected pc is an evil pc. :P
full system scans on my PC take a while going to be doing them overnight a couple times. This is my first ever time coming across something like this on this PC. So am a bit nervous. i uninstalled this Program called "GLS_Supporter" I saw it at first but the CCleaner said it was "A verified company" So I thought it was fine, found out it was triggering my scans. Uninstalled it with RevoUninstaller to get rid of the registry stuff too. Took of the extension and now all is good, having a bit of a hunch a bit of it still in the PC, going to be doing multiple scans over a couple days. Thank you very much for your help buddy! :D <333
Hope it turns out well. :)
Yeah, they can do it automatically, sneaky buggers they are =p
