First built at $1500. If you have any suggestions let me know. I know I mainly plan on using this for gaming/ streaming in 1080/1440. I have 500 more to spend on upgrades, I was thinking of getting a better CPU like the intel core i710700k or a better gpu like the 2070s. Let me know your thoughts.
 https://pcpartpicker.com/user/justinislit2/saved/FygRTW
https://linustechtips.com/topic/1220318-first-build-any-suggestions/
If you're streaming and playing at 1440p, a 3700X may be better utilized. Or you could go 2070 super and use Nvidias NVENC encoder instead. The 10700K could work intead of the 3700X, but it's a significant price premium for only a slight gain in gaming performance.
Could also get away with 650W quite comfortably. Obviously you could spend a lot less on AIO and ram, but I'm guessing you like the aesthetics so that's ok so long as you know you are giving up performance
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
Made a few changes. Better quality PSU (650W will be fine for you), GPU, saved a bit with another cooler and mobo. All SSD storage. Still blingy with RGB, but even a little cheaper than your list: https://pcpartpicker.com/list/fVKRWb
For streaming i'd maybe go with a 2070 Super instead: https://pcpartpicker.com/product/3sJmP6/nvidia-geforce-rtx-2070-super-8-gb-video-card-900-1g180-2515-000
Let me know what you think.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
For streaming you'll want to go with Nvidia for graphics, to take advantage of NVENC. Because of this, a 6-core CPU will be more than enough.
To stay under the $1500 mark and fit in a 2080 Super, you'd be looking at a Ryzen 3600 build:
PCPartPicker Part List: https://pcpartpicker.com/list/gPppcq
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($171.99 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($179.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($79.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($719.99 @ Amazon)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($68.98 @ Newegg)
Power Supply: be quiet! Straight Power 11 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.90 @ B&H)
Total: $1460.83
If you can bump the budget up some more, you could go for a 10600K instead. Granted this won't offer too noticeable of a benefit at 1440p, though at 1080p it will be better than the 3600:
PCPartPicker Part List: https://pcpartpicker.com/list/HynrFG
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  ($284.99 @ Newegg)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler  ($70.00)
Motherboard: MSI MPG Z490 GAMING EDGE WIFI ATX LGA1200 Motherboard  ($199.99 @ Best Buy)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL14 Memory  ($99.99 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($98.98 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($125.99 @ Best Buy)
Case Fan: Noctua NF-A14 PWM chromax.black.swap 82.52 CFM 140 mm Fan  ($26.90 @ Amazon)
Total: $1783.72
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
