So the left fitting leaks at 43'c, right at 45'c. I've changed fittings, tubing, looked for cracks and made it hand tight as possible.
I've changed the fan profile to compensate but it still has a very slow leak when it does read that temp. It's only those fittings.
Any help will be appreciated.
Specs
Ryzen 4 1400
1060 6gb
16gb Corsair Vengeance pro 3200mhz (running at 2999mhz due to first gen ryzen)
Block: Icue XC7
Fittings: Primochill Flex St 1/2 x 3/4
*I'm water cooling a 1400 because I'm new to OC, no need to worry about damaging anything because it's all about to be replaced anyway.
Proud owner of a custom water cooled Ryzen 1400. 5800x
https://linustechtips.com/topic/1220226-compression-fitting-leak-at-45c/
since it'll only leak at those higher temperatures i guess the thermal exapnsion if the plastics cause the seal to fail.
you could try tightening them some more, but you should be carefull with the Corsair stuff since it's really all just plastic.
What tubing are you using?
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
Thinking about putting another 360mm rad on top to compensate for the temps.
I've tighten them as much as possible by 2 hands and my whole body. It is all plastic which is why I didn't  really want to.
Mayhems Ultra Clear, it was cheap but after the release of the 4000 series and GPU I will be switching to hard line. I only used soft tubing because it was my first time water cooling and there's a lot of things I can only learn with experience.
Thinking about putting another 360mm rad on top to compensate for the temps because in summer it will be in at least 30'c ambient temp.
Could it be a slight disconnect between metric and non metric sizes? The Mayhem stuff is metric iirc and the Primochill imperial, which can potentially cause issues depending on the margin of error in the manufacture.
Yeah, I remember when researching people suggested using the same brand for fittings and tubing but due to covid  I couldn't exactly do this, I might see if I can grab some Primochill branded one.
I wouldn't worry too much about getting the same brand, but something in imperial sizes should give you an indication if this is the issue. I'd also check to make sure your tubing cuts are straight as they can be.
I’d be more concerned about the fluid temp. Not much room left before other failures.
They are 100% straight, I made sure of that and bought a pipe cutter just for it.
What's wrong with the fluid temp?
Upon further investigation it turns out the tubing is sliding out at the temp but still have water coming out between the fitting top when I push it back in. Like For Science said. Is there a glue I could use?
Edit: Just a thought it's the increased temp causing the fluid to expanding which increases pressure pushing out  the tube right? So I've got on my distro a G1/4 port that catches air, would it be a good idea to leave it open? It won't leak, will probably evaporate but should stop the tube from coming out?  My only concern is letting in bacteria.
Edit 2: Figured out how to turned down the pump to 2800rmp, temps equilibrium at 38'c  after stress testing with AIDA64. No leaks for now. The entire system is cooler all sits below 40'c except for GPU.
Edited by Npiet1
Possible answer
