Budget (including currency): 620$ CAD
Country: Canada
Games, programs or workloads that it will be used for: FPS games, maybe some games like GTA.
https://ca.pcpartpicker.com/list/vNdfb8
Hello I would like some help with this build I'm gonna make soon. I got a bit of help from some people in the forum making this parts list so here it is.
NOTE: I am not sticking with just the SSD I will get a HDD in the future. I just want to make it so I can play once I have all the parts and start adding the different parts later. Will this this SSD be better than the MX500, and will I also need to get a Network Adapter?
Thank you for helping :)
https://linustechtips.com/topic/1220165-good-parts-list/
1 minute ago, lavishly said:
now I have this https://ca.pcpartpicker.com/list/BD8CYH will the Gigabyte mobo support it?
yes, as long as it comes with the bios pre flashed. but as i'm not good with streaming, and the hardware involved, i would wait for someone else to weigh in on whether it will be a good choice with your setup for streaming.
https://linustechtips.com/topic/1220165-good-parts-list/#findComment-13805504
I'm sorry I'm a beginner to pcs how exactly will I set that up?
you shouldn't have to. read a few reviews on the board on the site you will be buying from, and you should see people mentioning whether it is, or isn't, pre-flashed. also, the box will have a sticker saying it's 3000 series ready. if it comes un-flashed for some reason, you would need a first or second gen amd cpu to flash the bios with before it would work with a 3300x.
https://linustechtips.com/topic/1220165-good-parts-list/#findComment-13805513
7 minutes ago, lavishly said:
Probably Streamlabs OBS if that's what you're asking.
I am not that experienced with streaming softwares but u might be able to select the nvenc as long as u really go with a gtx gpu instead of the cpu to encode the stream. I think u could go with the 3300x then if I am not completely wrong.
https://linustechtips.com/topic/1220165-good-parts-list/#findComment-13805515
