My question is, what will the NH-L9I handle as cooling capabilities go.
I want to build a pc that can only house a L9I, I want to know if I can put a i9 9900 non K under it and still be in happy temps land. If this is not possible would changing it out for a 9700 do it? Maybe changing out the included fan to a industrial PPC noctua fan? If anyone has suggestions leave em below.
I have no use in people telling me the TDP and wattage thats on the intel site, I'm well aware that the intel site says 65W but in reality the I9 9900 doesn't even come close to this efficient.
No I am not going with Ryzen I know they have great offerings but I dont like jumping on the new tech train. If your not convinced, Jayz made a whole video about why new tech is great but not always reliable.
https://linustechtips.com/topic/1220100-help-me-chose-my-cpu/
you probably wil be able to run a i9 but you may want to have some limitations in place incase your workload might overheat your cpu. a 9700 could be a safer bet
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1220100-help-me-chose-my-cpu/#findComment-13804934
If you just want someone to tell you its ok to shove an i9 9900 under a L91 , you can just say that. But keep in mind a lot of people here are going to want you to do something more reliable and aren;t willing to dish out bad advice so quickly.
I'd recommend you ask the same question on a subreddit as people are much more willing to give more comedic answers or just bad advice just to see someone else actually go through with it.
My advice... dont do it unless the cpu is mostly idle at all times.
https://linustechtips.com/topic/1220100-help-me-chose-my-cpu/#findComment-13804936
Most people here don’t like to give advice at all. They will tell you to use Google.
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
https://linustechtips.com/topic/1220100-help-me-chose-my-cpu/#findComment-13804944
From the limited material I could scrap together, a 9900 non-k shouldn't thermal throttle under an L9, but temps will run quite high, would recommend more cooler if possible, if not the 9900 will manage
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1220100-help-me-chose-my-cpu/#findComment-13804957
