Check if the 3.5mm plug is fully inserted.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/1217074-hyperx-stinger-problem/#findComment-13779022
-Threads Merged-
Please refrain from posting duplicate topics in multiple sub forums. Choose the forum you think best fits the question you have :)
https://linustechtips.com/topic/1217074-hyperx-stinger-problem/#findComment-13779224
