So I recently bought a  Geforce RTX 2060. While putting it into my PC, I realized my PSU only had a 4 pin, which didnt even fit the GPU. The PSU supplies 500 watts. What should I do?
My current build:
CPU: AMD Ryzen 7 5800X
Mobo: Gigabyte B450 Aorus Elite V2
GPU: XFX Radeon RX 6800 SWFT 319
RAM: Corsair Vengeance RGB PRO (4x8 3200MHz)
Storage: Patriot P300 128GB, XPG SPECTRIX S40G 1TB, WD HDD 1TB
Cooler: Corsair iCUE H150i RGB ELITE
PSU: Corsair RMx 750W 80 Plus Gold
Case: Corsair 4000D
Monitor: AOC Q27G2S
Keyboard: Corsair K95 RGB PLATINUM
Mouse: Roccat Burst Pro
Headphones: Roccat ELO 7.1 USB
Microphone: Roccat Torch
https://linustechtips.com/topic/1216736-psu-cable-not-going-into-gpu/
is your psu modular?
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
PCIe power connectors don't come in 4 pin. You're likely trying to plug in a CPU/EPS power connector, which will not fit.
What PSU do you have? If it doesn't even have a 6 pin PCIe connector, you probably want to upgrade it anyway.
Make sure it's the pcie connector not the eps connector
Usually the eps says cpu on it and the pcie cable has vga on it.
Phone: Pixel 3a (Purple-ish).
Build Log:
Where should it say this? The head or the cable?
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
Just now, MRDotted said:
The head
Build Log:
What model power supply is it? Does it have 6pin or 8pin PCIe cables?
Unfortunatly I dont know what PSU I have. I bought it quite a while back. I had a good look at it, but I cant find a 6 pin. If I do need to buy a new PSU, then I guess I'll be having to save up again.
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
Should be a brand and model on the label on the side of the power supply.
If you're unsure you can upload a picture of it and the cables that it has and I'm sure we would be able to tell you what it is and if it has PCIe cables.
No, it is not.
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
4 minutes ago, MRDotted said:
No, it is not.
upgrading is the only way forward in my opinion unless you wanna get freaky with your psu and some soldering stuff.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Dont see a brand or model so here is a picture. I looked at the cables but couldnt find an 8 pin. Also, ignore the dust, thats getting cleaned up today.
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
cables look like the stuff from the wish shopping video. I strongly advise upgrading. depending on your cpu, with a 2060, 500 watts wont leave you will much headroom for overclocking, upgrading and such
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
The label will be on the other side of the power supply facing towards the motherboard. Doesn't look great from what I can see though.
From the cables coming out of the power supply it looks like it has a 24pin ATX cable, a 4pin CPU power cable, and a molex/SATA power cable. Doesn't look like it has any PCIe cables coming out of the PSU.
Time to buy a new PSU I think.
Would adapters also be an option? I've found adaptors that allow me to plug the cables in the picture into my GPU.
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
Molex to pcie ?
Technically they would work but I would not recommend them.
Build Log:
6 minutes ago, TofuHaroto said:
Molex to pcie ?
Well seeing how I'm broke after buying the GPU, I'll get some adapters for now, and later on buy a better PSU.
My current build:
Case: Corsair 4000D
Monitor: AOC Q27G2S
I'm still interested in seeing what model power supply you have. I have my doubts that it is actually capable of outputting 500W, especially given the power cables it has - or lack of.
If you unscrew the 4 screws at the back of the case attached to the power supply you will be able to pull it out and have a look at the label that's facing against the motherboard tray.
Hm... Wild guess: ACE A-XXXBR? (XXX: 500/550/650/750/800, units range from 500 W - 800 W)
Images:
Picture 2 of 3Picture 3 of 3
Cables (500 W - 550 W PSUs):
  • 1 x 20 + 4-Pin Main Connector
  • ? x 6-Pin PCIe Connector (Unlisted)
  • 1 x 4-Pin 12V (EPS?) Connector
  • 2 x SATA Connectors
  • 3 x 4-Pin Molex Connectors
  • 1 x Floppy Drive Connector
Cables (650 W - 850 W PSUs):
  • 1 x 6-Pin PCIe Connector
  • 4 x SATA Connectors
SourceAce BR Black 500W PSU on CCL Computers.
1067451338_Parrot(HeyThere).gif.e97925793ccf804bfa896d9711ca294b.gif *promptly disappears* 1067451338_Parrot(HeyThere).gif.e97925793ccf804bfa896d9711ca294b.gif
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
Time to sound a little harsh, but I feel I need to be stern here.....
You have an old and garbage PSU.
It doesn't have the correct connectors for your graphics card.
If you use adapters, you'll start a fire.
You had $300 for a new graphics card.  Go spend another $70 on a PSU that was made in the last decade.
Or do the smart thing and return/sell the 2060, get a cheaper GPU and buy a reliable PSU for future upgrade.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
