First of all, le SPECS:
CPU: AMD Ryzen 5 2600 (non-oc, stock cooler)
GPU: NVIDIA GTX 1660 SUPER OC (GIGABYTE, 2 FAN VERSION)
RAM: 16GB DDR4 G.SKILL RIPJAWS V 3200MHz
PSU: Corsair CX550M
I recently replaced my old GTX 1050Ti with a GTX 1660 SUPER and i'm getting lower FPS than i expected, here is a picture of settings and a benchmark of SOTTR on HIGHEST settings.
I wouldn't mind if it was constant 60 FPS without random frame drops and microstutters, but they happen for some reason.
And here is a video from another guy who has the same specs but gets more fps than me:
https://www.youtube.com/watch?v=_NbSoDfcqn4
Shadow_of_the_Tomb_Raider_Screenshot_2020_06.28_-_14_50_01_72.thumb.png.cf2c70e3b9a396666b6dfbadc84a9d77.png
https://linustechtips.com/topic/1215375-lower-fps-than-expected/
Did you DDU when you installed the new card?
Desktop - i5-9600KF @4.8GHz all core, MSI Z390-A PRO, 2x8GB Corsair Vengeance 3000MHz, MSI GTX 1660S OC 6GB, WD Blue 500GB M.2 SSD, Seagate Barracuda 2TB 7200RPM HDD
Laptop - ASUS ZenBook 14 with ScreenPad, i7-1165G7, Xe iGPU 96EU, 16GB Octa-Channel 4200MHz, MX450 2GB, 512GB SSD with 32GB Optane
Old Laptop 1 - HP Pavilion 15, A10-9600P, R5 iGPU, 8GB, R8 M445DX, 2TB HDD
Old Laptop 2 - HP Pavilion 15 TouchSmart, i3-3217U, Intel HD 4000, 4GB, 1TB HDD
iPad 2018 - 128GB
iPhone XR - 128GB
4 minutes ago, blackviking03 said:
I DDU-ed it and the driver for the 1660S failed to install and then i reinstalled Windows and it worked.
Fair enough. DDU is my solution to most issues lol, but did you also DDU after reinstalling Windows?
Also double check the GPUs power settings in Nvidia Control Panel. Check that it is set to use all CUDA cores and that the performance mode is maximum (or something along those lines)
iPad 2018 - 128GB
iPhone XR - 128GB
When Windows was reinstalled, Windows, obviously, automatically downloaded a GPU driver, but i also DDU-ed it and then installed the new one.
Gonna check settings right now.
Fair enough. Fingers crossed the settings work 🤞
iPad 2018 - 128GB
iPhone XR - 128GB
Ah right, let me send you a screenshot of mine, see if there's any differences
iPad 2018 - 128GB
iPhone XR - 128GB
iPad 2018 - 128GB
iPhone XR - 128GB
Looks like you might want to change the power management mode. Your CUDA settings are good already I think
iPad 2018 - 128GB
iPhone XR - 128GB
Changed power management mode but it still falls under 50 in the first benchmark of SOTTR (first sequence during the night).
Have you tried running it with DX12 instead of 11 too?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Ah right. I just noticed, in your screenshot at the top you don't have DirectX 12 enabled. Give that a go maybe?
iPad 2018 - 128GB
iPhone XR - 128GB
35 minutes ago, blackviking03 said:
snip!
...something is wrong cause only 32% of the time in the benchmark were you GPU bound...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Can i fix that somehow?
Are you sure your AMD chipset drivers for your motherboard are installed propely?
I'm honestly not sure, Windows installed them i think.
What motherboard do you have?
Have you checked your temps make sure your CPU is not trottling?
Your motherboard has a cheap VRM?
ASUS PRIME B350M-K
Lemme check and take a picture of CPU temp in BIOS.
have you updated your BIOS?
