RTX Voice and FFmpeg
Go to solution Solved by BobVonBob,
Not currently. RTX Voice is only available as a real-time audio processor, but perhaps this will change in the future. For now you could try finding an audio editing software to clean the files up, or just run an audiobook overnight.
Is it possible to re encode an audio file in FFmpeg by passing it through RTX Voice?
I have a lot of audiobook files that are super crackly and playing them on my PC with RTXV significantly reduces this problem. Issue is that I never listen to audiobooks on my PC, I use my phone. So I was wondering if there was a way to set up a processing pipeline that didn't involve playing the audio in realtime, bridging my headphones and mic, and just recording that.
https://linustechtips.com/topic/1212896-rtx-voice-and-ffmpeg/
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1212896-rtx-voice-and-ffmpeg/#findComment-13746442
