Posted June 20, 2020 Components: Motherboard: X570 Aorus Pro Wifi CPU: Ryzen 9 3900X GPU: RX-580 8GB MSI Armor(Temporary) PSU: Corsair Rm850x RAM: Gskill Trident Z 32GB 3200MHZ Dual Kit. Hi, My Motherboard won't post and there are no beeps either. The CPU fan is spinning and lighting up, RAM Sticks are lighting up too but there's no display. GPU fans weren't spinning but reason could also be that since they are 'Zero Frozr' fans and don't spin when the load is low which is why I'm not sure. I removed the GPU and plugged in the HDMI directly to the Motherboard and still no post nor beeps. I don't know if it's the CPU, Motherboard or PSU. I took out the CPU and checked for bent pins but there aren't any. I'm really confused. I'd really appreciate any kind of help. Thanks. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 for the beeps, some motherboard dont have the beeps. for the no post check if there are any debug lights at all on the board. Please do the following: check the cpu for bent pins, take a look at your memory and look up the model number to make sure it is compatible with ryzen. PC specs: Ryzen 9 3900X overclocked to 4.3-4.4 GHz Corsair H100i platinum 32 GB Trident Z RGB 3200 MHz 14-14-14-34 RTX 2060 MSI MPG X570 Gaming Edge wifi NZXT H510 Samsung 860 EVO 500GB 2 TB WD hard drive Corsair RM 750 Watt ASUS ROG PG248Q Razer Ornata Chroma Razer Firefly Razer Deathadder 2013 Logitech G935 Wireless Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 You wont get any video output with that CPU from your motherboard because its not an APU. How long did you let it sit before turning it off? It could be doing memory training. I know my system takes a while to get any video output when it is retraining memory. Main Rig: Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, MSI Ventus 2 OC RTX 3060 12gb, Corsair H115i Pro AIO cooler, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600Ohm headphones, Creative Giga Speakers, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, LG SATA Blue Ray Drive, Corsair CX850M PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans, China ARGB SSD heat sink. HTPC: Erying 11800 ES CPU/Mobo combo, 32GB of Corsair LPX 3200 CL16, Gigabyte 4060 8gb LP, Thermalright AXP90 full copper cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case. STILL NO RGB! Retro Gamer PC: VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 Author 7 minutes ago, eeeee1 said: for the beeps, some motherboard dont have the beeps. for the no post check if there are any debug lights at all on the board. Hi, Thanks for the response. You're right. I'm so dumb that I missed that. There are 4 Red LEDs for CPU, DRAM, VGA and BOOT respectively. There's a Red light on the CPU. Should I go for a replacement or am I to do something? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 6 minutes ago, Felix D Rozario said: Hi, Thanks for the response. You're right. I'm so dumb that I missed that. There are 4 Red LEDs for CPU, DRAM, VGA and BOOT respectively. There's a Red light on the CPU. Should I go for a replacement or am I to do something? check for bent pins PC specs: Ryzen 9 3900X overclocked to 4.3-4.4 GHz Corsair H100i platinum 32 GB Trident Z RGB 3200 MHz 14-14-14-34 RTX 2060 MSI MPG X570 Gaming Edge wifi NZXT H510 Samsung 860 EVO 500GB 2 TB WD hard drive Corsair RM 750 Watt ASUS ROG PG248Q Razer Ornata Chroma Razer Firefly Razer Deathadder 2013 Logitech G935 Wireless Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 Author 16 minutes ago, eeeee1 said: check for bent pins There aren't any. The CPU was probably dead out of the box. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 12 minutes ago, Felix D Rozario said: There aren't any. The CPU was probably dead out of the box. I order to get post beeps, you need to plug in the little speaker on the FP. Looks like this. Do you have one? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 Author 16 minutes ago, ShrimpBrime said: I order to get post beeps, you need to plug in the little speaker on the FP. Looks like this. Do you have one? Sadly I don't. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 2 minutes ago, Felix D Rozario said: Sadly I don't. You can pick these up on E-bay for a few dollars only. Perhaps an old PC in the closet might have one. A local PC shop probably has them. Get this little speaker so you can further diag your rig. Otherwise it'll be mostly guessing. Then you can look up the post codes either at the owners manual or here at LTT I can give you a link just ask. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 Author 1 minute ago, ShrimpBrime said: You can pick these up on E-bay for a few dollars only. Perhaps an old PC in the closet might have one. A local PC shop probably has them. Get this little speaker so you can further diag your rig. Otherwise it'll be mostly guessing. Then you can look up the post codes either at the owners manual or here at LTT I can give you a link just ask. I'll order one. I'd like the LTT link as it would help out a ton. Thanks so much. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 20, 2020 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2020 Author Hi @ShrimpBrime, I plugged in the Beep Buzzers and just to be sure, I replaced my CPU with a new one. Same issue, CPU fan is spinning, RAM RGB is on, Red CPU Debug LED and no Beep Codes. I've reset the CMOS and have also tried using 1 RAM Stick at a time on different slots as well. Should I Q-Flash to a new BIOS? or is my motherboard dead? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 22, 2020 I would try a bios flash first before calling the board dead. If all else fails, warranty the board. That sucks Im sorry. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
